iR 3220 Color Displacement
  • CaptnRed
    • Apr 2011
    • 57
    [CQ] iR 3220 Color Displacement
    The original complaint was of wavy Magenta background, but after performing all the steps in Canon TP06 07a.pdf the magenta background went away only to be replaced with color displacement during copies and prints.
    To summarize the step in that tech pub:
    1) Upgraded the DCON Version to 38.02
    2) P-Print, Then cleared DC-Con
    3) Restored values of: PVE-OFST, ADJ-REFE, FEED-ADJ>REGIST, MF-A4R, MF-A6R, MF-A4
    4) Removed all drums and executed L-ADJ-O
    5) Adjusted DVTGT-M to -3
    6) Adjusted TC-Ref to 0
    7) Adjusted T-SPLY-M to -1
    8) Performed a CCD adjustment
    9) Got a bottle of Maker's Mark
    Like I said, it helped with the Magenta background but doesn't help to replace one problem with another!
    • 16083
    Re: iR 3220 Color Displacement
    see>read>>>>>ATTACHED TP03 174f.pdf
    Preventive measures for possible color displacement in the paper feed (sub scanning) and the main scan (front
    to rear) direction.
    also remove >PATCH SALT UNIT & CLEAN> SET BACK & CHECK POSITION
    • CaptnRed
      • Apr 2011
      • 57
      Thanks for the post! I will check these things one at a time.
      Is there a laser setting that could be causing a color displacement in the main scanning direction? This problem only happened after the DCON was upgraded to v38.02 and I performed all the adjustments that I listed above
        • 16083
        Print out a P PRINT
        Then do a DCON CLEAR
        POWER OFF\ON
        GO IN SERVICE MODE -PUT BACK DCON INFO from P PRINT
        POWER OFF/ON
        Do a Full Auto Gradation.
        • CaptnRed
          • Apr 2011
          • 57
          Originally posted by teckat
          Print out a P PRINT
          POWER OFF\ON
          POWER OFF/ON
          I'll try this too. Should be on Mon or Tues and I'll let you know how it goes!
          • canonbundy
            • Jun 2012
            • 607
            Init Colour Reg in SRV Mode 2 then Init colour Laser Units, perform full Auto-Grad.
            • boog
              • May 2014
              • 7
              Print out a P PRINT
              POWER OFF\ON
              POWER OFF/ON
              I go as far as leaving a door open when I go back in to put the #'s back in. That way the machine doesn't take any measurements between the clearing and re-entering. I also do a quick adjust, it appears to do line position.
              Like this:
              Print out a P PRINT
              Open right drawer
              POWER OFF\ON
              POWER OFF
              Close right drawer
              Power on
              Do a quick adjust
              Some machines require an extreme approach, and I have had to do those this way:
              Print out a P PRINT
              Perform manual Laser timing
              Open right drawer
              Power on
              POWER OFF\ON
              POWER OFF
              Close right drawer
              Power on
              Do a quick adjust
              These sure can be a challenge to get back once they get out of their happy zone. But, I have had the best luck by not letting the machine take any measurements between resetting the lasers and clearing and re-entering the DCON.
              • CaptnRed
                • Apr 2011
                • 57
                Finally got it fixed after manually adjusting the laser cams back into the home position and doing the second adjustment that boog suggested.
                Thanks for the help!
                  • 16083
