Offending command / Pagesize - mark - false on clc 3200 C1 - (what's up here)
  • AhaaOkay
    • Mar 2014
    • 24
    Trying to print via the fiery drivers and set document size smaller than media (12x18" or 305x457mm) size by at least 1/8 "0,315mm)
    the 12x18" is registered in the copier
    And I get the above postscript error !!
    Can anyone help me make sense of this.
    even if I choose print to fit I end up with this error !!
    Thanks in advance ;-)
  • AhaaOkay
    • Mar 2014
    • 24
    Re: Offending command / Pagesize - mark - false on clc 3200 C1 - (what's up here)
    Is there a similar table / info like this: http://www.copytechnet.com/forums/at...rt-ir2318l-pdf (Combination of Copy Modes Chart ir2318L .pdf)
    for the CLC 3200 C1+ mentioned here (post #13) http://www.copytechnet.com/forums/ca...tml#post340182
    What is the limits (min / max size ) of paper being used in the stack bypass
    Standard ?
    Non-standard ?
    TIA
    • teckat
      • 16083
      did u register the irregular paper size in Printer
      Stack Bypass:
      Irregular size (3 15/16" x 5 7/8" to 12 5/8" x 18" (100 mm x 148 mm to 320 mm x 457 mm))
      Paper Quantity: one to approximately 100 sheets (20 lb bond (80 g/m2), stack
      approximately 1/2" (10 mm) high)
      • AhaaOkay
        • Mar 2014
        • 24
        Stack Bypass:
        From my initial post: >> the 12x18" is registered in the copier <<
        But how about i/regular sizes like ;-)
        13x19" 330x483
        or SRA3 320x450
        Just trying to figure what is safe figures/printable area when comming from a PDF file / indesign/illustrator to any off these formats.
        From my understanding the printable area is a 1/8" less than the papersize
        The pictures from the manual above use some pretty antiquated drivers. The current driver from fiery talk about document size and media size. I can see that I'll have to do some screenshots for you with some current info and experiment a little
        Until you guys wake up over there I should be able to test things a little with different drivers ;-)
        Until then ;-)
        Any input welcome - I'll keep an eye open while testing ;-)
        • teckat
          • 16083
          13x19" 330x483
          or SRA3 320x450
          Until then ;-)
          I don't believe the 3200 series supports 13x19
          • AhaaOkay
            • Mar 2014
            • 24
            You're probably right the fiery driver is just an universal driver that likely supports several pieces of equipment from Canon.
            At the moment I'm not able to get anything out on the 12x18" at all be it in the manual feed tray or in a regular drawer (registered of course)
            Odd
            One should be able to print something intended for A4 at any size of paper if one choose fit/shrink oversized pages.
            But telling the copier to choose the 3rd drawer or from the stack bypass (manual feed tray) goes by like talking to a concrete wall ..... no result at all not even a sort of relief ;-)
            • teckat
              • 16083
              Odd
              What C1 Print Driver are u using / what is OP System ? Windows 8/7 ?
              http://www.usa.canon.com/cusa/support/office/imagepass_controllers/imagepass_c1/imagepass_c1#DriversAndSoftware
              iR3200/3220
              Copy/Print Sizes -
              Cassette Feeding = EXEC., STMTR, LTRR, LTR, LGL, 11” x 17”, 12” x 18”
              Optional Paper Deck = LTR
              Stack Bypass = 3-5/16” x 5-7/8” to 12-5/8” x 18” (100mm x 148mm to 320mm x 457mm)
              "When an imagePASS is connected the Convert Paper Size option must be configured on the imagePASS controller instead".
              Paper Size Override Function on the Canon Controller based printers is very similar to the setting on the Fiery based controllers called Convert Sizes.
              The purpose of Paper Size Override is to convert a paper size when the paper size that is set in the printer driver has not been loaded in a paper drawer. The paper that is printed on will be changed to the following sizes: Print Driver Setting Paper that will be printed on
              Letter ---> A4
              A4 ---> Letter
              11 X 17 ---> A3
              A3 ---> 11 X 17
              If [On] is selected, the paper size will be changed.
              If [Off] is selected, the paper supply message will be displayed and the paper size will not be changed.
              To Set Print Override:
              1. Press Additional Functions
              2. Select Printer Settings
              3. Select Settings
              4. Select Paper Size Override [On or Off]. (On newer Systems choose Paper Feed Settings and then Paper Size Override.)
              • AhaaOkay
                • Mar 2014
                • 24
                Thanks for all that info Teckat
                Just adding info here as I collect it ....
                I use this driver ...
                I'll go and have a look at things in the morning .... meanwhile
                Running this on Windows 7 (64bit)
                1
                Will walk through the utilities section of your drivers-link.
                2.
                Where does the version C1_ver2.1.1 utilities fit in.
                3.
                Am I blind or isn't there any postscript drivers on the US drivers site ?
                ahhhh ... chose windows 7 generic ;-)
                File Name:imagePASS-c1v2.1_PS_Vista_Print.exe
                imagePASS-C1 v2.1 PPD for Windows Vista/2003/2008/Win7 32-bit OS (Non-WHQL Certified).
                is the C1_ver2.1.1 utilities intended for this driver ?
                Have grabbed the Postscript drivers from here (besides the one I'm using)
                imagePRESS C1
                Here there's 3 different PS drivers
                4.
                I'll have a go at the good old PCL 5 driver ..... .. just to get things going
                Lots to have a closer look at
                • teckat
                  • 16083
                  When u have a Fiery connected ( imagePass C1) in your case,
                  U need to use the Drivers for it. & not the models (3200 ) drivers.
                  GO FOR IT
                  • AhaaOkay
                    • Mar 2014
                    • 24
                    GO FOR IT
                    imagePASS-c1v2.1_PS_Vista_Print.exe 01/11/08 75 KB
                    File Name: imagePASS-c1v2.1_PS_Vista_Print.exe
                    http://www.usa.canon.com/cusa/downlo...inTabView=true
                    everything I pointed to was for the imagepress C1 aka CLC 3200
                    imagePRESS C1
                    Maybe choosing OS and Language ... you'd see a perfect list
                    How am I set given that:
                    device boot rom ver. 70.01
                    device system version 86.01
                    device function version 81.00
                    printer version 38.02
                    Is there any correlation between drivers / system / firmware and printer version that makes a nice symbioses ?!
                    • teckat
                      • 16083
                      imagePRESS C1
                      Time to get the terminology straight------
                      I believe u have your models mixed up > a CLC3200 is the same product as a iRC3200 & NOT related to a imagePress C1 Printer.
                      do u have a
                      CLC3200/3220-C1 v2
                      or CLC3200-C1
                      believe they use same drivers
                      Multi PDL Network Printer Unit-C1- BOX
                      or
                      is this what u have
                      Color Network Printer Unit- C1 V2.1 EXTERNAL BOX
                      • teckat
                        • 16083
                        CLC3200/3220-C1 v2
                        PCL5e/5c, PCL6 Printer Driver v14.00
                        32bit and 64bit Windows OS
                        OLD/
                        Windows 7 Compatibility for Printer Drivers:
                        Canon UK - Windows 7 Compatibility Lists .pdf
                        • AhaaOkay
                          • Mar 2014
                          • 24
                          do u have a
                          CLC3200/3220-C1 v2
                          or CLC3200-C1
                          or
                          is this what u have
                          [ATTACH=CONFIG]25273[/ATTACH]
                          Well I'll check the display of the copier with the "C1" unit should give an idea to what it is
                          But in europe Canon kindly write CLC 3200/iRC3200N on the reference manual for obfuscation ;-)
                          I don't have any manuals for the "RIP"/ PDL unit so I'll take some camera-shots of
                          But if I can use command worksation from "efi" there's a good probability that it's a fiery rip.
                          (Un)fortunately we got it second hand (used with a lot of toner) as we ALSO have an iRC 3200N that we can use as spares.
                          We'll be a lot smarter during tuesday ... my monday got seriously screwed up in various ways ;-)
                          • AhaaOkay
                            • Mar 2014
                            • 24
                            This pd contains a few status/setup/configuration prints ;-)
                            pdf-status-setup.pd.pdf
                            • teckat
                              • 16083
                              [ATTACH]25288[/ATTACH]
                              Config page Shows u have a External Box ---EFI Printer Unit-C1 > EFI imagePass C1 > Same Animal-just different names for other areas in the world
                              u can do that under Control Panel Printer Tab
