Serial number PCB.
  • Rachid.Akli
    • Oct 2011
    • 595
    [Electrical] Serial number PCB.
    Hi to all,
    Can someone give me a help to locate the serial number PCB on an IR8500.
    Thanks in advance.
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
  • teckat
    • 16083
    Re: Serial number PCB.
    Originally posted by Rachid.Akli
    Hi to all,
    Thanks in advance.
    Rachid.
    ______;-\
    Serial Number PCB can only be obtained by contacting the Canon Technical Support Hotline.
    Counter Memory, Serial Number and Main Controller PCBs work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is electronically stamped with the serial number from the Serial Number PCB.
    Neither the Counter Memory PCB nor the Serial Number PCB can be swapped to other equipment. The Counter Memory PCB keeps track of the total count, which cannot be erased or changed. The service counters are retained by the Main Controller. These counters can be reset manually through service mode. When the Counter Memory PCB must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the Main Controller. This is retained in SRAM on the Main Controller PCB and held active by means of an on board battery.
    Serial Number PCB is located behind the Main Controller.
      • 23009
      Keep in mind that if you start swapping around serial number PCB's you will end up with a very nice doorstop. If you're thinking about it ... don't.
