Canon fixing film grease
  • kstan268
    • Apr 2012
    • 85
    Where can i get canon original fixing film grease or is there any grease which can replace the original grease..I had tried many type of grease to apply on Ir2870 or ir3245..but paper jam still occur jam code 207..is any of you guy out there solve this problem..please let me know plssss
  • teckat
    • 16083
    Re: Canon fixing film grease
    FY9-6011 GOOGLE IT
    FY9-6011-000 - Canon IR2230 Grease Item Inc.
      • 23009
      I know it's not OEM, but I've used Uniflor with good results, on all fixing films.
      Results for UNIFLOR
      • kstan268
        • Apr 2012
        • 85
        Originally posted by teckat
        FY9-6011 GOOGLE IT
        Is this Grease can apply to fixing assy..as i aware that this grease is not for high temperature used
        • teckat
          • 16083
          used on imagePress C1 FIX UNIT
          • libra
            • May 2010
            • 21
            Use littel quantity of vasline rub on heater body gentally , I just tried yesterday it worked
            • teckat
              • 16083
              U better make sure that your VASLINE does not have Petrolum in it.
              • popjumper
                • Oct 2013
                • 9
                try silicon oil. its the perfect for all fixing film and you will never regret.
                • teckat
                  • 16083
                  _____:--\
                  Not all silicon is the same ) read labels first-_- some gum up + turn black x
                    • 23009
                    I can't endorse either of these choices. I do believe vaseline is petroleum based, and silicon oil evaporates. Both are poor choices. =^..^=
                    • Brian8506
                      • 1665
                      I get the Uniflor from Precision and it works great. Blackcat recommended it years back. A little pricey as grease goes but it lasts a long time. Everything else, including the grease that comes with each film tends to burn up and cause the film to drag, thus the blurriness and jamming
                        • 23009
                        I don't know if you noticed Brian, but I thought the manufacturers of the aftermarket films are a bit parsimonious with the grease. I'd prefer to use about twice as much as they send along. It only really needs to be on the heater surface and the end bushings. =^..^=
                        • Brian8506
                          • 1665
                          Yes I did and that's why I use from the tube regardless of the film distributor. I can easily regulate it. BTW, nice word that parsimonious. I had to look it up on dictionary.com. Must have slipped past me in school
                          • kstan268
                            • Apr 2012
                            • 85
                            some of my fren recommand me to used a botton roller that come with one black rubber busshing(same lke Ir3300)did u see or try before?
                            • kstan268
                              • Apr 2012
                              • 85
                              but as i know c1 dun had fixing film...which part using this oil??
