IR C2020 E00000-0002
  • copyman
    Owner / Technician
    • Sep 2005
    • 4745
    Are codes cleared on Advance series the same as other canons? *, 2,8,. Can someone please post the exact procedure or email it to me if don't want to post publicly.
  • tykesupport
    • May 2014
    • 24
    Re: IR C2020 E00000-0002
    To clear error codes (E000, E001, E002, E003, E717, E719), COPIER > FUNCTION > CLEAR > ERR, 1) Select the item, and then press OK key.
    2) Turn OFF/ON the main power switch.
    • teckat
      • 16083
      ERR_To clear error codes (E000, E001, E002, E003, E717, E719)
      DC-CON_- Before execution of this item, be sure to output the service mode setting values by P-PRINT. After execution, enter necessary setting
      values.
      - The RAM data is cleared after the main power switch is turned OFF/ON.
      R-CON_- Before execution of this item, be sure to output the service mode setting values by P-PRINT. After execution, enter necessary setting
      values.
      JAM-HIST
      _ Clear of jam history
      ERR-HIST_Clear of error code history
      ADRS-BK_Clear of address book/The address book data is cleared after the main power switch is turned OFF/ON
      CNT-MCON_Clear of Main Controller service counter
      CNT-DCON_Clear of DC Controller service counter
      OPTION_Clear of service mode setting VL(OPTION)
      - Before execution of this item, be sure to output the service mode setting values by P-PRINT. After execution, enter necessary setting values.
      - This item is executed for the data on the Main Controller PCB, DC Controller PCB and Reader Controller PCB.
      MMI_Clear of user mode setting value
      To clear the user mode setting values (excluding values for Control Panel, common settings, and FAX).The setting value is cleared after the main power switch is turned OFF/ON.
      - Common Settings
      - Timer Settings
      - Adjustment/Cleaning
      - Report Settings
      - System Settings
      - Copy Settings
      - Communications Settings
      - Printer Settings
      MN-CON_RAM clear of MNCON PCB SRAM Board
      To clear the RAM data of the Main Controller PCB SRAM Board. All data on the SRAM Board is initialized
      Caution - Address Book, Forwarding Settings, Settings/Registration (Preferences), Adjustment/Maintenance, Function Settings, Set
      Destination, Management Settings, TPM Settings, etc. are deleted.
      - Since the file management information is initialized, images on the HDD cannot be read.
      values.
      - If this item is executed while a login application other than Default Authentication is activated, any symptom occurs. (e.g. The login
      screen is not displayed.) In this case, switch the login application to Default Authentication once.
