E061 please help me
  • mettacopias
    • Aug 2025
    [Error Code] E061 please help me
    Hi, im brazilian and i have a problem...my printer has a error all the time..this error is e061..the machine dont copy anything while this error still be on printer. Someone help me?
  • libra
    • May 2010
    • 21
    Bto first try to potential mske it zero try if works then replace primary corona snd hvt assy it ll br ok
    • SYED REHAAN
      Re: E061 please help me
      you try to change atm value 0 to 2 in service mode
      • teckat
        • 16083
        e061
        what model is this issue on ???
        • mettacopias
          I use the IR-6000, and I switched all the values that I know. I also changed the coronas and the values of body>po_cnt, function>dpc, more ideas? And try speak correctly for I understand..thank you.
          • teckat
            • 16083
            Error code E061
            Workaround :
            When troubleshooting Error code E061, the potential control can be disabled in: ServiceMode>Copier>Option>Tempo> F-POT-SW. This allows the image runner to run copies.
            A solid black copy Laser is defective.
            A white copy check the HVT, Primary Corona.
            If you get a copy, check the Potential Sensor.
            The drum support is held in by a screw. If the screw is missing you will lose the drive to the drum. This may cause an E061 code. The Part number for the locking screw is XA9-1090-000.
            Check MSW2, the switch could be mis-adjusted or loose.
            • northernlife
              • Sep 2011
              • 847
              • Brian8506
                • 1666
                [QUOTE=teckat;424584]Error code E061
                Teckat has a good point here. If the screw is missing or even loose you can get an E061
                • mettacopias
                  Anyway, I gave up looking for a solution to this error, I changed all possible parts and nothing was resolved. Thank you all.
                  • teckat
                    • 16083
                    What parts ?
