Canon iR-c4080
  • aAandy
    • Apr 2012
    • 369
    [CQ] Canon iR-c4080
    hello people
    got a machine with a weird blank stripe down the page, same place, all colours - the blank area looks like little white cylinders about an inch wide, one atop the next all the way down the page
    checked the secondary transfer roller & it looks fine,, can't be drums because the fault is the same with all colours,,, can only imagine ITB assembly, but before i pull it out & dismantle it, i was wondering if anyone has had something similar & can advise further
    thanks in advance
  • teckat
    • 16083
    Re: Canon iR-c4080
    Originally posted by aAandy
    hello people
    thanks in advance
    is this shown on PG10 TEST PRINT ?
    or when using DADF ?
    is this before Fixing ???
    Then> Suspect that the static eliminator can be arching to the ITB belt.
    The static eliminator is part of the Secondary Transfer Assembly.
    Secondary Transfer Assembly (FM2-5375-000)
    Also check the INTERNAL SEPARATION ROLLER >
