cannon ir 550 no lift tray 1
  • jrivera
    • Apr 2025
    good day everyone, I have a copier that will not lift tray 1, i have replaced paper feed assy. and drawer, still the same problem. There are no error codes, copiers operates fine from tray 2,3 and 4. Thanks everyone. If any more info. is required please let me know, Again thanks
  • kwazimoto
    • Jan 2007
    • 199
    the first thing I would check would be the connector plug that the paper feed asm. plugs into both sides they get bent and also can burn throu in the casing were you can not see so ohm them out.. if not the try a dc con clear.. do a p print out first..
      • 22927
      I've got a possibility for you:
      "Load Paper" indication intermittently from deck #1 or deck #2 (mainly deck #1). Excessively tight wire ties on the harnass from the paper lift motor to the DC controller. On the harnass from the paper lift motor to the DC controller cut wire ties, massage the wire bundle, and install looser wire ties.
      I hope this helps.
      • jrivera
        550 lift #1 assy.
        thanks everyone i'll give em a look,
        • lkrsardis
          • Dec 2007
          • 316
          no lift
          If you are not getting any lift at all, the lift motor is probably bad. Remove it but leave it plugged in to test it.
          Like the United States Postal Service It's a miracle it works!
          • yourownfree
            • Dec 2007
            • 474
            check the fuse to the lift motor
