canon irc5180
  • mramlawi
    • Jul 2011
    • 838
    canon irc5180
    Dear all ,
    I have a canon irc5180 working fine but i have a problem on the driver h1 v2.0 that if i want to choose the bypass side to print the machine didnt take from the bypass even i choosed it its just taking from the casette theres anything in driver must do to understand the bypass ? Other driver works fine just the h1-ps driver.
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: canon irc5180
    Originally posted by mramlawi
    Dear all ,
    do u have the PS Printer Kit installed
    For PS printing, the optional Color PS Printer Kit must be installed.
    For Color imageRUNNER C5185/C4580/C4080, the optional Color UFR II/PCL Printer Kit
    must be installed before installing the optional PS Kit.
    Under
    Additional Functions>Common Settings>Draw Eligibility For APS/ADS>
    Other choose Bypass to enable for printing.
    Also>Under Additional Fuctions>Common Settings>Draw Eligibility For APS/ADS>Printer see if a Bypass option is/now available.
    • mramlawi
      • Jul 2011
      • 838
      Re: canon irc5180
      Under
      thank you teckat ,
      i also had the PS kit on it and i made your steps but also its not workin its take from the drawers not from the bypass i used a pcl driver it works but on the PS driver not workin i wonder why .
      • teckat
        • 16083
        Re: canon irc5180
        thank you teckat ,
        Delete the PS driver/ then download again / make sure 5180 Printer description shows correct in driver properties
        • Canuck
          Tech Specialist
          • 1713
          Re: canon irc5180
          On all documents? Probably not... Open the document and look in page options or something similar. I see this a lot with Word...Word tells it to print from a certain tray even if you tell it differently in driver. Application overrides driver...SEEN MANY TIMES
          • northernlife
            • Sep 2011
            • 847
            Re: canon irc5180
            If get device status fails, then the driver crapped out.
            • mramlawi
              • Jul 2011
              • 838
              Re: canon irc5180
              yes in all documents also i changed the inside the driver settings same issue
              • teckat
                • 16083
                Re: canon irc5180
                so PS Driver defaults to the cassettes for Paper size selection on BYPASS
                is this on all size selections using PS DRIVER
                PS DRIVER SETTINGS
                1. Go to the Start>Settings>Printer folder. Right click on the printer in question and choose Properties.
                2. Go to the Device Settings tab, then click "Form to Tray Assignment".
                3. In the Form to Tray Assignment window, choose Stack Bypass and highlight all the types of paper which you intend to use.
                4. Click OK.
                is this the driver u are using
                Canon U.S.A. : Office Equipment : imagePASS-H1
                imagePASS-H1 v2.0 PostScript Driver for Windows 32 and 64 bit Operating Systems. This driver supports Windows XP/Vista/2003/2008/Win 7/Win 8/Win 8.1/2012.
                • mramlawi
                  • Jul 2011
                  • 838
                  Re: canon irc5180
                  PS DRIVER SETTINGS
                  4. Click OK.
                  thanks teckat ,
                  but the website not let me download the file to check if thats it givein me error also the steps that you wrote it for me i couldnt find it (driver setting) start ....
                  • teckat
                    • 16083
                    Re: canon irc5180
                    thanks teckat ,
                    U have a H1 FIERY & a PS Kit installed in this printer ?
                    what ver. is H1 ?? 1.2 or 2.0
                    the support different driver ver's.
                    see link below
                    Canon imagePASS-H1 Drivers Download for Windows.
                    Copier Models: Supported Print Controllers:
                    imageRUNNER C4080i / C4580i / C5180i - UFRII/PCL Printer Kit -N1 (standard)
                    - PS Printer Kit -N1 * (optional)
                    - imagePASS H1 ** (optional)
                    - ColorPASS GX100 ** (optional)
                    imageRUNNER C4080 / C4580 / C5180 - UFRII/PCL Printer Kit -N1 (optional)
                    - imagePASS H1 (optional)
                    - ColorPASS GX100 (optional)
                    * PS Printer Kit-N1 requires that UFRII/PCL Printer Kit-N1 and iR 512MB Expansion RAM-C1 be previously installed.(bringing total memory on copier to 1.5 GB)
                    ** Requires the optional Open Interface Board on the 'i' models.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Re: canon irc5180
                      What OS workstation running?
                      • mramlawi
                        • Jul 2011
                        • 838
                        Re: canon irc5180
                        Win7
