Fixing roller not cleaning properly in canon IR6000
  • smrtamang
    • 10
    [Misc] Fixing roller not cleaning properly in canon IR6000
    hi all,
    is there any solution for web clutch setting or web speed setting coz my fixing roller is not cleaning well in my canon ir6000.
  • northernlife
    • Sep 2011
    • 847
    Re: Fixing roller not cleaning properly in canon IR6000
    Web's dry out rather quickly. Also is the web advancing? If not the gears tend to seize up that drive the web and will need replacing.
    • aco.bk
      • Sep 2012
      • 130
      Yes,replace web and check Arm,One Way .Figure 810 ,part 19 in pc.
      FF6-1428-000 ARM, ONE-WAY
      • copier tech
        • 8144
        As said above, replace all those cheap plastic gears & the one way clutch arm, all cheap & worth doing.
        Also i've seen some techs reverse the cleaning web, not a good idea as they dry out!
        • Brian8506
          • 1664
          I replace as a kit
          4-FS6-0105-000-Gear
          1-FS6-0104-000-Gear
          1-FB1-6833-000-One way bearing
          1-FB2-7228-000-One way arm
          1-FB2-7230-000-Shaft
          Make sure the shaft that the gears sit on and the shaft that goes thru the middle are clean. I usually drop a little oil on them. Works like a charm after.
          • northernlife
            • Sep 2011
            • 847
            You can depress the lever that the solenoid fires in order to see if it's free turning and it drives the web. If it's stiff or stuck or not depressing fully then it's one of those gears. I'm assuming you part checked the solenoid in service mode and heard it fire?
