Canon IRC3380i paperjam
  • creatus
    • Jul 2025
    [Jamming] Canon IRC3380i paperjam
    Hello
    I always get paperjam even with A3 and A4.
    When i print from duplex do not jam.
    Can someone Help me please? Thanks
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IRC3380i paperjam
    Vert path roller is worn/dirty, one way clutch that drives it is slipping. Or the door is off of the lower hinge and not closing exactly right.
    • creatus
      Thanks for your reply.
      It's all ok with the vertical Path Roller.. and the door close well...
      Any more ideas?
      • northernlife
        • Sep 2011
        • 847
        Without an actual jam code this is the best I can do from here from what I've seen in the field. If it doesn't make registration it's something with the door, vertical path or lower right door (But I see that it's been modded) If you push on one side of the lower right door (front and back) does it still jam when you push on them?
        • creatus
          even when i push the door it still jam...
          There are no error code on the display. only paperjam
          • teckat
            • 16083
            so A3/4 will not jam from same paper trays while selecting duplex ?
            is this on copies & prints
            do u know how to view the JAM CODES in service mode
            • creatus
              so sorry.. i try to find out how to find the JAM CODES.. but i can't find it...
              • northernlife
                • Sep 2011
                • 847
                add functions > 2+8 > add functions > Copier > Display > Jam
                Jams are sorted by occurance We just need the code itself, 01XX 02XX Let us know we'll tell you how to fix it.
                • teckat
                  • 16083
                  SERVICE MODE-Level 1=
                  press Additional Functions Key (once)
                  press #2 & 8 key at the same time (release both)
                  then press Additional Functions Key again (release it)
                  FF: = Jam type (first two numbers)
                  00xx Unused
                  01xx Delay jam
                  02xx Pileup jam
                  0Axx Jam at power ON/jam during warmup
                  0Bxx cover open jam (applies to all covers)
                  0Dxx Transparency-related jam
                  ff: or xx last two numbers = Jam sensor (printer unit)
                  that will show sensor location
                  • Nutstar
                    • Mar 2011
                    • 110
                    daft question but is the blue wheel set to the correct oriantation
