error code E000007-0000
  • erico
    Hi friends, please tell me how to fix the error code E000007-0000 in Canon iR2320l, the user emptied some toner fron drum to cartridge toner, began printing with some dark horizontal lines, which did not occur when a document is copied, then appeared the error code E000007-0000. Will change new toner cartridge and the error persists, I must do.
    Thank you
  • copier tech
    • 8172
    Re: error code E000007-0000
    When you say "the user emptied some toner from drum to cartridge toner" you mean they are running the machine on waste toner!?
    This error is a fixing fixing rotation fault. I suspect what's happened is the waste toner has soiled the fixing film patch.
    You will need to vacuum out all the toner from the dev unit & add fresh.
    Then fix the error by removing the fixing unit, & cleaning the white patch on the film.
    However I would recommend you replace the film ass'y as it could be damaged.
    Bad user hope you charge them for this call !!!!
    • erico
      Thanks for the quick response copier tech; can be sure that charge you very well to this bad user, as I said, made such atrocity. Tomorrow morning make the cleaning work, I will keep you informed of any other mishap, best regards.
      Erico
      • dreamz80
        Thank you
        hi,
        this error code comes out when your fuser film sleeve is torn or faulty...
        so need to replace..
        thanks,
        dreamz
        • dreamz80
          Thank you
          hi,
          so need to replace it..
          thanks,
          dreamz
