Canon IR 3200 Error code E0002-102 and cant get into service mode
  • dmd56
    • Jul 2014
    • 17
    [Dead] Canon IR 3200 Error code E0002-102 and cant get into service mode
    I have a Canon ImageRunner 3200 and I found what appears to be a transparancy wrapped around the heat roller. Removed it with no apparent damage, but I keep getting a error code of E0002-102, and I press * 28 * immediately and get no response. So I can't access service mode. Any help would be greatly appreciated.
  • Brian8506
    • 1664
    Re: Canon IR 3200 Error code E0002-102 and cant get into service mode
    Addl func/2 and 8 at same time /addl func should get you in service mode. Then copier/function/clear/err/ok and power off and on
    • dmd56
      • Jul 2014
      • 17
      Thanks I'll try that.
      • vigour
        • Aug 2010
        • 1038
        That "transparency" was the upper roller coating.
        You will get smudging when you do heavy coverage
        • dmd56
          • Jul 2014
          • 17
          It appears that the key pad isn't working. That's the reason that I can't get in to service mode. Can any one give me some insight on where to start on the key pad trouble shoot mode?
          • vigour
            • Aug 2010
            • 1038
            push each button to see which is working.
            some may have swithed service mode to *49*
            check that out.
            • teckat
              • 16083
              check for a stuck key/
              all keys should have an easy release download> then upward when depressed
              • dmd56
                • Jul 2014
                • 17
                Well again I thank every body. with the experience's I've had with Xerox K'bwds.. I ordered one on E-Bay. Cheap enough solved the problem, good as gold.
                Thaks to all.
