CANON IR2270 ALWAYS JAMS
  • mramlawi
    • Jul 2011
    • 838
    Dear all ,
    i have a canon ir2270 and its jams too much the Jam code is 0107 as i saw the figure they putted its jamin on PS13 (which means its the fixing sensor) but i wonder it looks ok .the paper always jams some time under the Drum ,and some times at the 2nd delivery tray .
    is theirs any solution for this , i also tried to change the bypass door also the 2nd inner delivery and i changed the pick up feed unit for the 1st cassette and still the same problem always jams .
    thanks
    Distinguished road makes you jewel in rough
  • ernesto
    • Oct 2011
    • 430
    HI
    If It jam in doble side mode....
    I think the problem is the paper humidity....in a4r it'll work
    ...in a4 you should update firmware and adjust in service mode .... I am going to send you by mail when I can.
    All the best
    • cdanger
      Re: CANON IR2270 ALWAYS JAMS
      Originally posted by mramlawi
      Dear all ,
      thanks
      Hi
      Check the registration sensor for a worn tip. I had one recently where replacement of the sensor flag (FL2-4520) resolved the problem.
      Regards,
      Charles
      • canonbundy
        • Jun 2012
        • 607
        Originally posted by cdanger
        Hi
        Regards,
        Charles
        Or cut a piece of mylar/thin plastic & stick to Flag - quick & cheap.
        Maybe replace Fixing Assy - Fixing Film grease may be gummy & not allowing the sleeve to rotate fast enough - check for E007 errors.
        • ernesto
          • Oct 2011
          • 430
          HI
          http://www.copytechnet.com/forums/ca...am-0105-a.html
          All the best
          • northernlife
            • Sep 2011
            • 847
            0107, bad ps13 - Can you trip it in service mode part check and verify functionality?
            worn reg sensor flag
            Vertical path rollers are they grey or black?
            there's a mod for the door that came out after this was released to get rid of that foam crap that some schmuck thought would be a good idea.
            All I have in my own files for this code.
            • Brian8506
              • 1665
              Also check if pre reg flag sticks. The other end rests against a rubber damper pad that gets old and sticky and can prevent paper from getting past the flag. There are a bunch of those on the guides on the door too that cause these problems.
              • mramlawi
                • Jul 2011
                • 838
                Originally posted by ernesto
                HI
                All the best
                Thanks alots Ernesto the problems solved on 2 machines as you sent me the mail i followed the steps and no more jams at all
                regards
