Canon iR3320i looking for Ethernet PWB
    • 23008
    My end user managed to mangle the pins of the network connector. Does anybody have an Ethernet board that they can part with for a reasonable fee?
    If you've got it, snap a photo and attach. I'd like to confirm that it's the right part. =^..^=
    • 23008
    Re: Canon iR3320i looking for Ethernet PWB
    bump.
    • bigmark
      • Sep 2008
      • 39
      I have had some luck just soldering a new Cat 5 connector to the board on other models with this same issue. They are a standard connection of pins that connect to the board. Takes longer but on older boards, its some times easier.
        • 23008
        Originally posted by bigmark
        I have had some luck just soldering a new Cat 5 connector to the board on other models with this same issue. ...
        I have too, I guess I'm just getting lazy. I'll give it a shot this weekend. =^..^=
          • 23008
          Silver soldering never looks as good as the old lead/tin solder, but it's done and meters out good.
          We'll see if it will connect tomorrow morning. =^..^=
          • Brian8506
            • 1664
            Did it work?
            [ATTACH=CONFIG]25887[/ATTACH][ATTACH=CONFIG]25886[/ATTACH]
              • 23008
              Yes ... and no.
              Yes, I can ping, and get to the web interface, but no further. There is an admin password on the web interface that I cannot get past.
              No, it still won't print or scan to SMB via crossover.
              The next step would be for me to check the network settings ... but the password stops me cold. I don't know if there is a secondary problem with the ethernet card or if it's just a simple setting that I cannot access. =^..^=
