IR-C9075 error E25-0310
  • Gabriel
    • Jun 2006
    • 139
    [Dead] IR-C9075 error E25-0310
    IR-C9075
    error E25-0310
    Cyan toner empty
    The button in the screen to release the toner bottle doesn't work.
    I have replaced:
    FM3-4716-000 HOPPER ASSEMBLY, COLOR
    FU6-0584-000 ONE-WAY GEAR, 18T
    But still the same problem. I'm missing something?
    any input is welcome
    Regards
    Gabriel
  • vigour
    • Aug 2010
    • 1038
    Re: IR-C9075 error E25-0310
    The shaft to push the door open is not coming forward far enough.
    As far as I remember "error clear" will be of some help
    I have not solved it yet, but my workaround is to manually crank the toner out, and research till the next time it needs toner.
    some guy told me the gear fixed his, but you disproved that by changing the gear.
    My last one started immediately after I replaced a whole hopper rack. I was not about to rip it out again
    • Gabriel
      • Jun 2006
      • 139
      thank you for your fast response
      I did the error code in service mode, but same error code.
      Manually Im able to lock /unlock all toner bottles.
      Im running out of ideas
      Any help is welcome
      Regards
      Gabriel
      • Gabriel
        • Jun 2006
        • 139
        After replacing PS83 machine is running but it has a background, it start as orange but after 300 copies now is pink.
        I can't run gradation adjustment because the background.
        Customer is mad and Im tired, any idea, somebody had this issue and fix it.
        Regards
        Gabriel
        • vigour
          • Aug 2010
          • 1038
          Background usually needs new drums.
          On rare occasions a dev
          • Gabriel
            • Jun 2006
            • 139
            vigour
            You are right replacing yellow developing unit did the trick
            regards
            Gabriel
