skewed image df and glass
  • Jerrygbs
    • Dec 2008
    • 193
    [CQ] skewed image df and glass
    Copier runs copies from memory great (network info) but from glass or df image is skewed. I can't seem to find the adjustment in my manual ir 3570 any help will be appreciated.
  • northernlife
    • Sep 2011
    • 847
    Re: skewed image df and glass
    if prints are fine and both the glass and df are giving skewed copies, then your scanner is physically not straight inside the reader unit. If it was just df there's an adjustment for that but because it's both I'm pointing at that scanner being crooked.
    • Jerrygbs
      • Dec 2008
      • 193
      The registration was way off causing no paper buckle for correct registration, sorry to waste your time
      • northernlife
        • Sep 2011
        • 847
        We all do it buddy, we all spend hours chasing some stupid shit and then look to the left and let out a couple cursewords.
        • Brian8506
          • 1658
          Nice fix!
          • teckat
            • 16083
            2270 / 2870 / 3570 / 4570
            copies are skewed from the Glass or Feeder
            Make sure the White Plastic Mount for the CIS unit is not cracked
            This will cause a skew in the copy during scanning.
            Replace the CIS Mounting Bracket, if this applies to your issue_Part Number FM2-3368-000
            also do an RCON Clear
            Service Mode level 1: Copier > Function > Clear > RCON. Highlight RCON clear, press ok and then power cycle the imageRUNNER.
            then Re-Enter the appropriate values using the following service mode items:
            a. service label (behind reader unit left cover)
            a-1. CIS read position adjustment (fixed reading) COPIER>ADJUST>ADJ-XY>ADJ-X
            a-2. main scanning direction position adjustment(fixed reading)
            COPIER>ADJUST>ADJ-XY>ADJ-Y
            a-3. shading position adjustment (fixed reading)
            COPIER>ADJUST>ADJ-XY>ADJ-S
            a-4. main/sub scanning direction MTF value
            COPIER>ADJUST>CCD>MTF-MG
