Code Erreur E007- 9902 on IRA C7065i
  • lamichedepain
    • Aug 2025
    [Error Code] Code Erreur E007- 9902 on IRA C7065i
    Error code: E007- 9902 on IRA C 7065i.
    I ve changed the whole set and the Fusion card that controls the merger.
    I have toujour the same error code: E007 -9902.
    who has an idea.
    thank you
    see you
    Lamichedepain.
  • vigour
    • Aug 2010
    • 1038
    Fm3-4835
    Pressure crossmember assy
    This is the assembly with the thermistors
    • teckat
      • 16083
      Re: Code Erreur E007- 9902 on IRA C7065i
      Machine would display an error code E007-9902 with the lower fixing pressure belt centered.
      Solution :
      Replacing the Lower Fixing Pressure Belt position sensors PS76 and PS77 (WG8-5783-000) resolved this case.
      • lamichedepain
        hello.
        I chenge all full merger.
        and I always quote the same error code, same email, making a clear Err.
        So ?????
        • lamichedepain
          hello.
          I changed the entire set fusion.
          and I always quote the same error code, even by making a clear Err.
          So ?????
          • teckat
            • 16083
            Originally posted by lamichedepain
            hello.
            So ?????
            Check for scraps of paper in the fuser connector /can block>& could cause interruption of proper signal to release sensor & release motor when u powered up printer
            Is the lower pressure belt stuck in the raised position.
            if so u have a big job to
            re-engage the pressure gear to lower the cams,
            >Try cutting all wire ties on fuser and harnesses to and around the DC Controller.<
            or replace
            FM4-1378-000 Cable, Main Fixing Drawer (frame connector) and
            FM4-1282-000 Cable, Fixing Drawer (drawer connector)
            Is this Printer on a dedicated outlet line ? )nothing should be sharing the outlet or it's supply line(
            big ? were u ever trained on this models series
            The C7000 series uses a 120 volt lamp (FK2-7883-000) and the C9000 series uses a 208 volt lamp (FK2-7884-000).
            If the lamps are not correct the copier will display a fixing error code.
            • teckat
              • 16083
              READ THIS TWO PUB's
              imageRUNNER ADVANCE C7055/ C7065/ C9065S PRO/ C9075S PRO/ C9065 PRO/ C9075 PRO
              describes measures to minimize the E004-0205/0501/0502, E006, E007-9902 error codes.
              E007-9902:
              Pressure Belt displacement failure (Full displacement of the Pressure Belt or failure of
              the Pressure Belt Position Sensor).
              E007-9902:may occur due to the following:
              Factors at Fixing Drawer Connector Terminal
              - Foreign substances
              - Poor contact and/or deformation of terminals
              Factors at Fixing Feeder Assembly Open/Close Switch (SW7)
              - Mounting position failure of Fixing Feeder Assembly Open/Close Switch Lever
              - Mounting position failure of Fixing Feeder Assembly Open/Close Switch Holder
              Defect of Fixing/Feeder Driver PCB Assembly
