iR3045 - How to scan?
  • agriz
    • Aug 2014
    • 9
    Hi
    I have installed Scangear. I selected the printer iR3045 on scangear.
    Then, I closed the scangear and opened microsoft word.
    Insert -> picture -> from scanner to camera.
    I pressed the button scanner. But it says scanner is offline. Confirm that scanner is online, and then start scanning.
    But in canon i don't see any option named scan.
    It is copy, express copy, send, mail box, print jobs.
    Please tell me how to scan..
  • Brian8506
    • 1665
    Re: iR3045 - How to scan?
    You need to get the scan tab on the screen. I believe its in service mode level 2 option, user, then I believe you're looking for UI-scan. Set to 1 and scan tab should come up.
    • agriz
      • Aug 2014
      • 9
      Hi
      Please can you explain this in detail?
      How can i bring that scan option in the touch screen?
      • Brian8506
        • 1665
        Service mode/level 2/copier/option/user/ui-scan/change to 1 and touch ok. Are you a tech?
        • agriz
          • Aug 2014
          • 9
          No. I just use it in my shop.
          I am not able to find the service mode option in my printer.
          Or should i enter the ip address of the printer in browser url to change this?
          Don't get mad. I know it is simple to change but i am not able to find it
          • Brian8506
            • 1665
            Press additional functions then 2 and 8 at the same time then additional functions again. then you should see service mode and follow the steps above.
            • agriz
              • Aug 2014
              • 9
              It is in service mode level 1
              I see there, copier, feeder, sorter, fax, board
              • agriz
                • Aug 2014
                • 9
                It is getting changed to level 1
                I pressed additional function and 2 to change it to level 2 and then i saw nw-scan instead of ui-scan.
                I set that to 1
                But i don't see scan option in the tab
                • agriz
                  • Aug 2014
                  • 9
                  Hi
                  Are you there?
                  • Brian8506
                    • 1665
                    You have to scroll. That's why there's techs. Change that back. If you don't see it look under body
                    I set that to 1
                    • agriz
                      • Aug 2014
                      • 9
                      I am seeing ui-rscan under body. Is it okay to enable it?
                      thanks for your helps.
                      • agriz
                        • Aug 2014
                        • 9
                        It is working. Thanks for all the help.
                        Do you know which software will make it simple to scan instead of ms word?
                        Thanks again
                        • northernlife
                          • Sep 2011
                          • 847
                          foxit, nuance, Any document management or pdf creator will allow you to scan through the scangear driver into the app. Every tech has a preferred solution for these apps.
