canon 210S E007 code
  • lakeman78701
    • May 2008
    • 44
    What is an E007 on a Canon Imagerunner 210S? I tried to put the machine into service mode, but it would not go in using *28*. Help please. After going back to the shop and looking at a manual, I found that the service manual is also for a GP200, which of course I dont have. Anyone got a page or the whole manual? This is a big chain store and is using a 9 year old copier as their main unit, their second copier is an analog, and the manager says they cant buy a newer copier because they are cutting back on budget. I thought about telling him about carbon paper.
  • kwazimoto
    • Jan 2007
    • 199
    a e007 is a fixing film has become displaced.. more then likely it need to be replace.. the film will more to one end and cause this problem...it could also be the film motor.or sensor.. all in the fixing unit...
    • rajeshkumarind
      • 12
      open the front door see the meter side one small hole
      put one the pin see the display top corner $ then press * two time enter the service mode
        • 23009
        Its been a while since I've seen one of these. Use the asterisk in the "head" shape for additional functions, not the asterisk on the keypad.
        So: *, 2 & 8 together, *
        Now E007 is the fixing film not centered. Either the film is destroyed, or the person that installed the new fuser did not run the procedure to center the film.
        If you need to run the procedure to center the film get yourself a manual. I don't remember all the steps.
        • jajees
          reason is the fixing unit
          please check the fixing unit, the film may be damaged , or the problem will be with the motor or the film should be ccentered
