IR 3300 Paper Unit Parts Numbers
  • yormets
    • May 2009
    • 336
    I need a part inside the lift and feed unit that has no part number listed for it. Can anyone help? I circled the part on the diagram. It's a plastic piece with a leaf spring attached to i. It releases the lever to hold the lift in place when the draw is inserted.
    ThanksScan10001.PDFScan10001.PDF
  • yormets
    • May 2009
    • 336
    Re: IR 3300 Paper Unit Parts Numbers
    I am trying to post a picture.Scan10001.PDF[ATTACH]
    • copier tech
      • 8144
      You might need to order the complete paper fed unit!
      However look very closely at that part, many plastic Canon parts have the part number molded into them.
      • MunsterTech
        • Sep 2014
        • 381
        you will need to order the whole pick up assy, which is the A4 and A3, i would be suprised if canon still stock these as they are a very old machine now and obsolete!
