iR3045 Paper jam
  • tee2520
    • Jun 2013
    • 37
    iR3045 Paper jam
    Paper always jam this position. Please advice. Thanks
  • teckat
    • 16083
    Re: iR3045 Paper jam
    [ATTACH=CONFIG]26324[/ATTACH]
    [ATTACH=CONFIG]26325[/ATTACH]
    how/where is paper stored ???
    01xx delay jam
    02xx stationary jam
    0202 jam can be caused by the sensor flag for PS11 not responding quickly or getting stuck. If the flag is not responding quickly an extra wrap should be added to the PS11 actuator.
    0107-replace the vertical path roller
    Jam Code (ADF-related)
    0003 =registration sensor delay--PI3
    0047 =1st sheet delivery sensor delay--PI3,PI4
    0007 =delivery sensor delay--PI3,PI4
    • laitang
      • Nov 2012
      • 627
      You should rebuild the Cassette Pickup Solenoid.
      • copier tech
        • 8192
        i'd be looking at the fuser, the films can stall causing this jam issue, especially if you are not using genuine Canon film ass'y.
        • ernesto
          • Oct 2011
          • 430
          Hi,
          I suppose the cassette paper size 2 is right. it seems there is a double feed, maybe the solenoid in the cassette pick up assembly 2 is sticky.
          Others tips about jams ......http://www.copytechnet.com/forums/ca...ways-jams.html
          All the best.
          • JAYAN PRINTO
            Registration senser arm will stick on the upper side near the senser due to melting the sponch, remove the melted sponh. U can identify it by moving the sencer arm upward by hand it will stick a moment and then only the arm will release.
