IR 3225N jam code SR6 and SR1
  • mido
    • Nov 2011
    • 177
    Hi,
    I have a problem in IR 3225N paper jam in DADF with code SR6 and SR1.
    when press start key the pick up roller of the dadf try pick up the orginal but still in the tray and jam
    I changed the pick up and feed roller of the DADF but still same jaming
    please any advise about this problem,
    Regards
    Mido
  • copier tech
    • 8172
    Re: IR 3225N jam code SR6 and SR1
    Those codes are not jam codes.
    Are the DF rollers actually turning?
    There is a oneway drive clutch in the pick up roller unit AND in the DF it's self, if the rollers are not turning a drop of oil on both clutches might help.
    • laitang
      • Nov 2012
      • 627
      Did you sure that ARDF cover is fix?
