Yellow background
  • kissyxerox
    Yellow background
    Hello
    I am having ir c 3200. when i take copy or print yellow background appears in all copy. please advice
    with regards
    kissy xerox
  • djzolla
    • 71
    seems like your drum is old mate! how old is it? when u go into service mode display/misc what does yellow say in figures? if its high like past 2 hundread change the drum
    • regalcopy
      • Oct 2007
      • 58
      need to change yellow drum unit
      do u get yellow background in running coies?
      either u get new drum unit or modify by using some older drum units. you can use charging roller of other drum unit, if u have old ones(used).
      in india u get new drum unit sets! (40K).
      how to modify/get units pm regalcopy@rediffmail.com
      • kajsa39
        • May 2008
        • 28
        yellow mellow
        If it's only on copying but printing to the machine is fine then i would clean the optics, if both printing and copying are producing yellow backgroung then replace the drum.
        Remember to calibrate after.
