IRAC2020i E025-0100
  • Elmo
    • Feb 2010
    • 541
    IRAC2020i E025-0100
    Good Morning
    Could any of you canon guru's help
    I have a canon irac2020i with E025-0100
    i replaced the magenta toner supply motor assy (it was locked with toner and the gears worn)
    but im still getting the error
    iam looking at poss dc controller or has anyone had this before an can tell me what im missing
    I Used To Live To Fix Things Now i Fix Things To Live
  • Elmo
    • Feb 2010
    • 541
    Re: IRAC2020i E025-0100
    i replaced the dc controller
    all looked good then E025-0200 cyan toner motor assy
    you know when its 1 of them days
    • teckat
      • 16083
      Originally posted by Elmo
      Good Morning
      E025-0100 is occurring at power on.
      clipping wire ties from J24 on the DC Controller to the magenta toner feed assembly resolved the error code.
      The part number for the magenta toner feed assembly is FM3-8085-000.
      • Elmo
        • Feb 2010
        • 541
        Thanks for the reply teckat i will give it a go
        • Elmo
          • Feb 2010
          • 541
          removed all cable clips still getting errors
          if i leave the magenta toner bottle out of the machine it runs up to preparing toner
          then throws up E025-0300
          with the magenta toner bottle in it runs up but then goes straight to e025-0100
          i can see the motor turning (the motor assy i fitted was from a working machine)
          going to replace the wiring loom from dc controller to toner supply assy see if it does anything
          • Elmo
            • Feb 2010
            • 541
            Machine now working
            Replaced wiring loom from dc cont to toner supply pumps
            not one of canons better models
            • teckat
              • 16083
              Machine now working
                • 2621
                Had 025-300 today.
                There's a sensor arm inside the hopper assy that can get covered in toner much like the 2880 series.
                May help someone in the future.
