Canon IR2800 Technical info
  • Rye
    • Aug 2025
    hi,
    just got a used canon IR2800. Display language is in Norwegian and no other languages available.
    anyone knows how to fix this and whether there is a way to reset the entire machine for new passwords, settings, and configuration?
    thanks
  • xcopytech
    • Aug 2006
    • 1794
    if there is no another language, then you should call service tech to upload new language to your machine
    • Rye
      what service tech? u mean the local canon distributer? isn't there another way?
      what about resetting the machine? is there a method for that?
      • xcopytech
        • Aug 2006
        • 1794
        you can check under tools if there is another language in machine.
        if norwegian language is only language canon tech have to use SST and upload another language to your machine.
        • alex@wocltd.com
          • 430
          you can dump everything-but be prepared to set it back up
          you can check via serial number what market is was meant for-if european market -english is the core language and by dumping evreything you'll get back to that
          • Rye
            hi,
            it is European. how can i Dump? is there tool for that?
            more importantly cannot access the password. is there a way to reset that? or maybe a master password?
            • Rusty old cat
              Language problem.
              GO into service mode *28* Select Copier/Option/Body/Config. Use + and - keys to scroll through options until languages is displayed + and - to select language you want. press OK. Turn off main switch on machine and back on. Give that a try.
              • Rye
                hi
                thx for above but the only language it shows is Norwegian.
                again the more important challenge is resetting the Machine entirely. unfortunately no one is able to reply.
                is there any instructions for step by step network setup (a thread, manual or something) as my driver is not self finding the Printer.
                • nivssluck
                  • May 2008
                  • 228
                  IR2800 language
                  you need Service Support Tool (SST) and 2800-2200-3300 system software to download LANGUAGE to your machine..
                  i have SST and system software...this is my email add..my_sharp_kuk@yahoo.com
                  • pearlpdy
                    • Jul 2008
                    • 44
                    need 3300 system software
                    plse send me your 3300 system software to me its very big help for me, my e-mail add is pearlpdy@yahoo.com
