Canon ir3300 fuser assembly
  • ITT Rental
    • May 2025
    [Electrical] Canon ir3300 fuser assembly
    I have Canon IR 3300 was running well before but now after
    I turn it on it show up with red blinking signal on the screen
    where the fuser unit is and the machine start with out any
    noise, please any one out there help me with this matter, Thanks
  • ARUN MISHRA
    • 80
    Re: Canon ir3300 fuser assembly
    what display say .......error or jam
    sigpicARUN KUMAR MISHRA
    • ITT Rental
      Nothing but red blinking light show up pointing to
      where fuser assembly place and show open front
      panel and left side panel which is I did few times
      and still have the same problem.
      • copier tech
        • 8100
        There is no red blinking light near the fuser on this model.
        Can you take a picture of the machine including the screen?
        • ARUN MISHRA
          • 80
          take a photo of the display and post
          • MunsterTech
            • Sep 2014
            • 377
            you mite have a lazy sensor in the fixing assy, had them stick so showing a constant jam at startup
            • toner cartridge
              • Sep 2014
              • 33
              please take a photo for " what errow showed in the machine" when problem,
              to see and understand more clearly.
              copier part supplier
