Re: Canon iR2270 - Network print error #853
Iam more confused then u.
Which is installed>
UFR II Printer Kit-E3 or PCL/UFR II PrinterKit-E2_??.
I repeat_#853=This error occurs when the Network Multi-PDL Printer Kit-E1/or is not installed and a driver different than UFR is being used to print. Installing and using the Canon UFR driver corrects the error.
Note that the PCL or PS driver will cause the error when the Network Multi-PDL Printer Kit-E1/E2 is not installed.
If printer is working with original parts, why are u playing around with this memory._?
Bottom line_
-Boot Rom ver. must match current Printer Firmware ver.
-Memory has nothing to do with Boot Rom ver.
If Copier works as as stand alone & u have an issue setting it up for Network Print that is a separate issue.
Explain exactly what the issue is & what u are trying to accomplish.
Which is installed>
Bottom line_
