Error code E 532 -0001 on Saddle finisher K4.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Hi to everybody.
    I have this code error in a Saddle finisher K4 : E 532 -0001.
    The motor of the staple unit does not moves.
    I checked the main switches of the finisher, the PCB drives, but it's all ok.
    Suggestions ?
    P. S. :Is there a way to put the finisher in "limited function"?
  • vigour
    • Aug 2010
    • 1038
    Re: Error code E 532 -0001 on Saddle finisher K4.
    No Limited Function on this, No DIP switch to turn stalper off either.
    The harness between stapler and controller flexes and eventually break.
    Not fun to replace.
    There is apart number somewhere with the stapler base and harness
    • laitang
      • Nov 2012
      • 627
      From SM:
      • teckat
        • 16083
        Originally posted by Ingranaggio_rotto
        Hi to everybody.
        Suggestions ?
        What model is K4 on ????????
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          It's the model installed on Canon iR 105 +.
          I think the cause of fault be the main cable of the PCB Driver . (It's broken )
          But must be verified.
