Canon IR3035 solid Black Band length wise on document
  • tibbs
    • Aug 2008
    • 225
    Hello I have an canon ir3035 when making copies from the glass the copies are coping out with a solid black band down the length of the copies in the LTRr direction. But when making copies from the document feeder there is no black band. Have done a couple of checks but I just lost.
    Can anyone help.
    • 23010
    Re: Canon IR3035 solid Black Band length wise on document
    Are you sure it's not the other way around? Lines through the DF, but not off the glass? Dirty optics or slit glass could easily account for that.
    If you are correct ... well it would have to be some sort of image processing problem. I would start by cleaning and re-seating the ribbon cables, especially to the CCD. =^..^=
    • tibbs
      • Aug 2008
      • 225
      Its on the glass for sure not the document feeder.
      • teckat
        • 16083
        U need to check the condition of the Ribbon Cable as posted by blackcat4866 /
        part number is FH2-7174-000. It is item 17 circled below.
