Misalignment of the color magenta on iRC 1028.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    When I start with my problems on field I do not finish ever !
    In a iRC 1028, I have a misalignment of the Magenta....
    I changed the ITB unit, but the fault remains.
    I changed the toner Magenta.
    The same problem.....
    Suggestions ?
  • Iowatech
    Not a service manager
    • 3930
    Re: Misalignment of the color magenta on iRC 1028.
    For a faster answer, you might try posting your question here:
    http://www.copytechnet.com/forums/canon/
    It probably would help if you could share a picture of the print defect you are experiencing.
    Good luck.
    • ernesto
      • Oct 2011
      • 430
      Suggestions ?
      I had a similar problem four months ago.
      Firstly, I tried to clear dc controller ( service mode-copier - VIFFNC-clr dcn- turn off and turn on the machine)but it did not work. After that
      I checked dc controller connectors, and it works a couple months, after that the problem appeared again. Clean the laser unit ......and the machine it is working until now.
      All the best
        • 16083
        Suggestions ?
        Magenta color is not aligned correctly.
        If the black cover under the Magenta drum had to be removed for servicing
        the cover may be out of position, causing one side of the Magenta Toner / Drum Cartridge to be raised.
        Try Re-fitting the black cover shown in the following photo to correct the problem.
        or
        Did u try to remove Laser Unit & Re-Seat it
        • Ingranaggio_rotto
          • Oct 2010
          • 275
          Thank you for your suggestions.
          Then you'll know!
          • Ingranaggio_rotto
            • Oct 2010
            • 275
            Hi!
            I found the solution !
            The flat cable of the laser unit was damaged !
            Thank you for your help !
