Hi all. I have a Canon IR-Adv that is fairly new (under 1 year) and has recently started producing printouts that have a stained background - shading of black toner. What would be the cause and can it be fixed? Thank you.
IR-Adv C2230 - Dirty Printouts
Re: IR-Adv C2230 - Dirty Printouts
yep, Bk drum, take it out and you will see toner all over the drum....pain in the butt these machines, i have had an ongoing issue with a magenta drum, leaking, replace drum, machine comes up with error, clean laser, still same, replaced drum...again, still error, replaced laser, still error....upgrade firmware in between all that and still same. Now supect the hopper motor or something along those linesComment
did you try putting the old drum back in the machine?Comment
^^ Can confirm this - I had to do this a few months back for about 2-3 weeks. Often on I would get a drum which would flash e020 with a wierd subcode.Comment
After replacing drum, laser, toner motor and still with E020 for magenta, turned out to be the DC controller! Bloody machines are so bad and inconsistent we are not selling them anymore!Comment
I agree, saw one yesterday, black background on prints, drum was only at 79%, I have had some success in cleaning them, also in service mode you can change the upstream cleaning, this can help, but only temporarily. Get used to fitting lots of drums!Let us eat, drink, and be merry, because tomorrow we may die!
Maybe it could be useful
Enya (enya@chinaeternal.com)
302 Found
you can pay by western union or bank transfer.COPIER MODEL DESCRIPTION OEM-PN CET-PN USD/PC Master Pack CANON iR ADVANCE C2020/2025/2030 iR ADVANCE C2220/2225/2230 Drum Cleaing Assembly N/A CET5100 20.00 1Pc
The gross weight of 20PCS of drum cleaning assembly is about 4.00KGS,volume is about 0.016CBM
the shipping freight is about $95.00 by TNT
All the best
I do not sure if it will work to increase the drum life, I have never tried it.... it is a part of the drum unit
Has anyone tried it ?
All the bestComment
