Error code
  • Riyadh hossain
    • Jul 2025
    Error code
    copier is ir3300 and show E0003550001. If any solution please help
  • Lijodamodaran
    service manager
    • Sep 2014
    • 56
    Re: Error code
    Do you replaced the MFC ??
    • Lijodamodaran
      service manager
      • Sep 2014
      • 56
      Re: Error code
      If so replace the ID pcb also from d same machine
      • Riyadh hossain
        Re: Error code
        I just change heater unit
        • teckat
          • 16083
          Re: Error code
          Where u swapping PCB's before ERROR 355
          Mismatch of serial numbers of three items: Serial Number PCB, Main Controller / Image Processor PCB (SRAM) and Counter Memory PCB.
          1. Put back all original PCBs into the equipment!
          2. Do not utilize a used Counter Memory PCB or Serial Number PCB from any other equipment.
          3. Ensure connector J1023 is connected.
          Items to keep in mind when attempting to troubleshoot the Soft Counter circuit:Counter Memory, Serial Number and Main Controller PCBsE355 error code is due to no communication between the Main-Controller board and the Serial Number board below it. The boards are connected by a 11 PIN yellow connector and cable.
          This yellow connector must be re-seated on the new Main-Controller board when changed. The connector must be seated firmly on the board.
          When this error occurs, you must go into Service Mode and clear the error code. How to clear the error code:
          1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
          U MAY NEED TO GO INTOLEVEL 3
          Additional Functions button> then 28 together>then Additional Functions button
          Additional Functions button then 19 together>then 3
          COPIER>FUNCTION>CLEAR>E355-CLR
          Turn OFF and then ON the equipment.
          2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
          3. Under the [FUNCTION] tab, select the [CLEAR] option.
          4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
          5. Reboot the machine.
          If the error occurs again:
          1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
          2. Re-seat the Main-Controller board into its slot.
          3. Go into service mode and clear the error code as explained above.
          * If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
