Remote Operation viewer v1.2
  • NakSumpu
    replied
    Re: Remote Operation viewer v1.2
    How to connect Remote operation Viewer to ir-adv 6275 machine?
    Thank you.
    replied
    Originally posted by syedshamim3
    I am trying to access my imagePRESS C1 and ir6570 through Remote Operation viewer v1.2, but neither connects. But I am able to ping both the MFPs and also able to access its pages using its IP address. What could be the issue? Remote UI is also enabled in the machines.
    u have a image Pass fiery connected ??
    Make sure that port 5900 (VNC), is open on the imagePASS.
    In order to facilitate this, go into the "Network" setup menu of your imagePASS controller and select the "Ports" option listed under "Security".
    Enable port 5900 as outlined below.
    is Remote Operator Kit installed on iR6570 & iPRC1 both need the Kit activated to use Viewer
    When trying to connect to an imageRUNNER that has the Remote Operator Kit installed with the Remote Operation Viewer application, you may run into the following message:
    --Could not connect to the device at the specified IP address.
    On the imageRUNNER, check the following setting:
    1. Press Additional Functions.
    2. Hit System Settings.
    3. Scroll down and select Remote Operation Settings.
    4. Enable this option and enter a password to authenticate the remote connection.
    After this option is enabled, reboot the copier and try to access the imageRUNNER again. In the Remote Operator Viewer application enter the password which was set in step 4 above.
  • syedshamim3
    started a topic Remote Operation viewer v1.2
