Remote Operation viewer v1.2
  • NakSumpu
    replied
    Re: Remote Operation viewer v1.2
    Originally posted by ts-lx
    VNC license code:
    7531 3618 0529 7308 6137 3836
    after I input the VNC license code, the machine displays an error Code E748-9000 what do I have to do? Please help me
  • ts-lx
    replied
    Originally posted by NakSumpu
    Serial Number : NMC10915
    Email : sesens08@gmail.com
    VNC license code:
  • NakSumpu
    replied
    要安装vnc功能,可以向我提供序列号
    replied
    Originally posted by giogi
    To install the vnc feature, you can provide me with the serial number.
  • giogi
    replied
    Originally posted by teckat
    ? Translated🤔
    replied
    要安装vnc功能,可以向我提供序列号
    ? Translated🤔
  • ts-lx
    replied
    要安装vnc功能,可以向我提供序列号
    replied
    I have done the above steps, but I still can't find Remote Operation Settings.
    [ATTACH=CONFIG]46898[/ATTACH]
    What should I do?
    thanks.
    Canon ImageRUNNER Advance: Remote Operation Software
    Link Instructions PDF below
    Adobe Acrobat
  • giogi
    replied
    but are you sure that in IRADV 6275 the remote operator is by default and not an option?
    check:
    press counter> device information>check device configuration> and read if the Remote operator appears among the options present
  • NakSumpu
    replied
    What should I do?
    thanks.
    replied
    Press [Management Settings] → [Licenses / Others] I can't find [Remote Operation Settings]
    [ATTACH=CONFIG]46873[/ATTACH]
    What do I need to do for the Remote Operation Settings to appear?
    Remote UI
    08KR-22R
    This mode enables you to use the Remote UI (User Interface) to operate the machine and change settings.
    1
    Press (Settings/Registration).
    2
    Press [Management Settings] → [License/Other] → [Remote UI].
    3
    Press [On] → specify each setting.
    If a screen prompting you to change a System Manager PIN is displayed, change a PIN by following the procedures described in "Specifying the System Manager Settings," and then set this function to 'On'.
    Press [Off] → [OK] to disable setting the machine from the Remote UI.
    Press [On] for <Use SSL> to use SSL communication.
    Select [On] for <Use Reference Print> to allow printing by entering it URL.
    NOTE
    Before setting <Use SSL> to 'On', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
    Any changes made to <Use SSL> are also applied to [Use SSL] in [MEAP Settings] in [Management Settings] (Settings/Registration). (See "MEAP Settings.")
    When the login service is set to Default Authentication and [Department ID Management] is set to 'Off' but the System Manger ID is specified:
    When settings other than above are specified:
    Specify each setting → press [Next].
    Specify each setting for access by general users → press [OK].
    Press [Allow] to allow access by general users, or press [Do Not Allow] not to allow access by general users.
    When you press [Allow], to set a PIN if necessary, press [Access PIN].
    Specify each setting → press [OK].
    imageRUNNER ADVANCE 6275 / 6265 / 6255
    User's Guide-----------
    LINK-
    https://oip.manual.canon/USRMA-0112-zz-CS-enUV/contents/1T0001918020.html#11c5649f75809413c96448c907e44a4b
    Remotely operate the machine from the comfort of your desk!
    Remote UI enables you to access the machine from your computer.
    Check the status of jobs and consumables, and restart or shutdown the machine, all from your computer.
  • NakSumpu
    replied
  • NakSumpu
    replied
    [Windows 32bit & 64bit] Remote Operation Viewer V2.3.0
    https://condoroffice.co.uk/manuals/iradv350/contents/1T0002813907.html
    Enabling the Remote Operation
    1.
    2.
    Press [Management Settings] → [License/Other] →[Remote Operation Settings].
    3.
    Press [On] → [OK].
    Press [Password] to set the password.
    IMPORTANT
    To perform the procedure described in this section, you must log in to the machine as an administrator. (See "Logging In to the Machine as an Administrator.")
    This mode is enabled only after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "How to Turn On the Main Power."
    NOTE
    You can enter up to 8 alphanumeric characters for the password.
    replied
    How to connect Remote operation Viewer to ir-adv 6275 machine?
    Thank you.
    1.
    2.
    3.
    Press [On] → [OK].
    IMPORTANT
    NOTE
  • giogi
    replied
    try to use Remote Operation viewer v2.2
