need help.. how to clean developer ir6570
  • 813200217
    • Oct 2014
    • 51
    toner ink get into unit 1, so i need to clean, how to do it?
    after some time it became so much ink
  • DAG COPIERS & COMPUTERS
    • Oct 2010
    • 860
    Re: need help.. how to clean developer ir6570
    You need to use a 'Common sense approach' to this problem! First observe and establish or identify the source of the toner leakage and why; cleaning the developing unit is not a big deal, remove it from main unit, empty it of toner , using a blower remove any residual toner on cylinder, then use a solution of 'Brasso' on a piece of rug to wipe and 'polish' the magnetic cylinder. Allow to dry, re-polish and you are done.
    • Brian8506
      • 1664
      Check the pre transfer assembly. Vacuum it out. May have to replace scraper blade in there. Probably spilling down to t/s unit
      • V-P
        • Apr 2011
        • 679
        First time I hear about this. Why in magnetic cylinder ?
        • 813200217
          • Oct 2014
          • 51
          can anyone upload the video in yooooooooooutube how to clean the developing?
          i want to try clean it by myself..
            • Oct 2010
            • 860
            Developing cylinder! I thought the poster wants to know how to clean the developing assembly...and that would involve emptying off toner, i suppose? Sorry, seem to have misinterpreted his post.
            • habibi
              • Jun 2011
              • 12
              you should clean it with a
              could be leaking toner
