ir3300 fax problem.
  • vandezo
    I don't know
    • 161
    ir3300 fax problem.
    i wake up in the morning.. get my phone..
    i hear i can't receive a fax..... when i check the cable, print, copy, setting machine is normally...
    then i check, whit my phone.. i hear tone, but there is not fax tone, is phone tone.. (no modem tone in my IR3300)..
    plz somebody ... where's the problem, or any setting to solve that?
    Thank advance..
  • linuxxpwin
    • May 2008
    • 205
    "i hear tone, but there is not fax tone, is phone tone."
    Are you saying you get 2 different tones one for fax and another for phone?????
    Linuxxpwin
      • 23009
      If I'm interpreting this correctly, when you call the Canon fax, something else is answering the phone before the fax does.
      And that's your answer. Something else is picking up the line before the fax can answer.
      I came across this exact situation at a bank that has some sort of alarm system sharing the line with the fax. The AC power had been lost over the weekend and the modem for the alarm system had reset to it's default, (1) ring. The fax answers on (2) rings. So guess who takes all the receptions? The computer modem.
      They asked me to please disconnect the offending modem. I told them I could not, would not touch equipment relating to their alarm system. That's up to the alarm system people. =^..^=
      • vandezo
        I don't know
        • 161
        when i ONHOOK then input the number, usually I hear the sound modem after 3 times sound "tuut" phone. this only just telephone sound not move to sound modem, impressing machine fax not incircuit... i was replace the main control PCB is solve the problem.. but what happen to my main control before
          • 23009
          Are you able to transmit? It's possible that an enduser turned off Auto Reception. If the machine is set to Manual Reception or Answ. Machine it will never answer unless the Start key is pressed to initiate reception. =^..^=
          • vandezo
            I don't know
            • 161
            TX is OK,
            RX is set to auto..
            my friend say "are you having a fax machine?"...
            is any setting hwo i made?
              • 23009
              I don't understand. Can you rephrase your question?
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Sorry man..but you've completely lost 90% of the techs that could help you...anyone you know with a better grasp of English so that we could help you?
                • ps/pcl
                  TECH SPECIALIST
                  • Jun 2008
                  • 35
                  solution
                  hi dear
                  even i faced this probem
                  solution :
                  backside of the mc u can find fax controller
                  therer will be two jumpers
                  remove jumpers and switch on the mc
                  m/c wil popup error
                  swith off the m/c
                  put back the jumpers and switch it on
                  ur problem ios resolved
                  if not change the fax controer board
