Canon IR Adv C5030 Error E00002703-00
  • Mark in England
    replied
    Re: Canon IR Adv C5030 Error E00002703-00
    Originally posted by dan7777
    Problem :
    Error code E027
    Solution :
    It has been found that the D cut portion of the drive gear can strip out and not allow drive to the developer. The drive gear is a X shaped gear.
    The gear part number is FC8-4338-000.
    That is how the code shows on the control panel but Canon only uses three numbers for Error codes EXXX-(XXXX). Cyan is a good bet.
    Hi
    just a quick 'thank you'-X shaped gear was broken on the cyan dev unit end. Bit daft having a unit that needs quite a bit of torque to be driven by a small gear on a tiny diameter shaft!
    Many thanks
    Mark
  • Canon345
    Guest replied
    Hope its not this.
    In this case, a gear was missing on the set on hopper assembly. The gear is not available as a part, so the set on hopper assembly had to be replaced Here is a picture of a set on hopper assembly with the gear in place.
    The part numbers for the set on hopper assembly are:
    5000 Series Black FM3-5980-000
    5000 Series Color FM3-5990-000
    5200 Series Black FM3-9660-000
    5200 Series Color FM3-9657-000
  • dan7777
    replied
    Originally posted by Mark in England
    ....now I'm no betting man, but I'd say there's a fair chance you've just explained why I can't find the error code!!
    MANY Thanks!!
    Mark
    Problem :
    Error code E027
    Solution :
  • Mark in England
    replied
    Originally posted by canon33
    I think it should be E027-0300. Has to do with cyan developer and or supply. Suspect bad drive gear on end of developer or possibly a problem with dev/drum drive assy. Good luck.
    MANY Thanks!!
    Mark
  • canon33
    replied
  • Mark in England
    started a topic Canon IR Adv C5030 Error E00002703-00
    Off to help out another dealer tomorrow and have to take a look at this machine for them. The error code isn't in the service manual so I wondered if anyone had any ideas please??
    Grateful for the help.
    Cheers
    Mark in England
