IPF750 message: cannot cut paper
  • White_Toner
    • Aug 2009
    • 71
    [Jamming] IPF750 message: cannot cut paper
    Hi, to all techs!
    The machine cuts paper without any problem.
    Cutter moves to the left, then to the home position,
    but roll of paper doesn't rotate back, and message: message: 'cannot cut paper' appears.
    Sometimes machine works correct.
    I can't uderstand which sensor makes signal that paper is cutting....
  • mramlawi
    • Jul 2011
    • 838
    Re: IPF750 message: cannot cut paper
    How many metes the machine work also check the cutter condition to keep working stop the automatic cut and cut manual until u solve ur problem to ur client
    Distinguished road makes you jewel in rough
    • White_Toner
      • Aug 2009
      • 71
      Hi, mramlawi!
      The machint works 2 monthes - enougth fresh :-)
      Cutter is in good condition. The edge is clear after cutting - no problem :-(
      • jure
        Originally posted by White_Toner
        Hi, mramlawi!
        Hi,
        did you ever solve this problem?
        Marko
