Firmware
  • T3chworkal
    • Aug 2025
    Firmware
    Morning all, I have been asked to update firmware on a Canon IRC1021i to allow a 3rd party software to run on it. I am experienced on most makes except Canon re this procedure, could anybody possibly help with where to obtain it and how to update it?? Many thanks, Paul.
  • teckat
    • 16083
    Re: Firmware
    CiRC1022 Flashing procedure.pdf
    iR1022C > EXAMPLE
    The software used to flash this model is called the User Support Tool.
    X=The Service Support Tool is not used in flashing this model imageRUNNER=X
    1- download the latest firmware
    Make sure to extract the file, the default folder location is C:\Canon File Folder\SST System Software Folder\SST Files.
    Launch the .exe and it will show you the following:
    Choose Next >
    Make sure the C1022 is in Download Mode and connected via USB or network cable.
    Then click Next >
    You can specify the machine by printer name or IP address. Then click Next > .
    Start when ready. The firmware will be downloaded to machine. C1022 will show Updating Firmware Do not reboot.
    Once you see the message:
    Firmware is complete.
    The device will restart automatically.
    Press OK and the C1022 will reboot.
    • teckat
      • 16083
      Re: Firmware
      To enter Service Mode press the Main Menu button, then 2, then 8, and again the Main Menu button.
      COPIER > DISPLAY > VERSION<VERSION>
      MAIN= Display of the version/checksum/date of Bootable (product program area)
      BOOT= Display of the version/checksum/date of BootROM (boot program area)
      ECONT= Display of the ROM version of the recording engine
      what is firmware ver. on Printer ?
      what is 3rd Party software ?
      who told u that u need to update ?
