e748-2010 (black screen) iradvc5030
  • canonjay
    • Mar 2014
    • 10
    [Error Code] e748-2010 (black screen) iradvc5030
    pls..help...i got error e748-2010 (mc cant boot) after energy saving mode...(black screen)
  • Dutchman
    • Jan 2011
    • 58
    Re: e748-2010 (black screen) iradvc5030
    Flash board error. First disconnect H/D and see if the error changes if so then take steps to clear that error first.
      • 16083
      The imageRUNNER will boot with a black LCD and display an E748-2010 error code. The engine and accessories will cycle and home itself. The E748 will not be logged in Service mode due to the incomplete boot process.
      The E748 indicates Error in Board ( Flash PCB )
      The Sub Code 2010 indicates IPL ( Initial Program Loader ) is not found.
      Workaround :
      Re-seat the Flash PCB ( Boot Program ) if this does not correct the error replace the Flash PCB.
      The Flash PCB has an orange led which is lit on a working unit.
      Note: The part number for the Flash PCB is FM4-0792-000.
      If replacing the Flash PCB does not resolve the issue. Replacing the Main Controller 1 should correct the error code.
      Below is a picture of Main Controller 1 with an arrow pointing to the Flash PCB.
      • canonjay
        • Mar 2014
        • 10
        i already changed maincont 1 n hdd..same symptom.. flash board i not change yet...i try 1st
        • canonjay
          • Mar 2014
          • 10
          Workaround :
          i will try change..the flash board......tqvm
          • repeatcopiers
            • Sep 2008
            • 591
            Workaround :
            I am having this same issue on an Adv4045, would this same fix apply? We went out today and reseated Main Cont 1, and flashed the system, it went away for a few hours but now has the same E748-2010
              • 16083
              ADVANCE 4025 / 4035 / 4045 / 4051
              E748-2010
              The following information are details about the Error Code from the Service Manual.
              In this case, the SATA FLASH board was replaced and Main Controller Two.
              E748 2010 00 = Flash board error
              Description = IPL (Initial Program Loader) is not found
              Remedy = Flash board replacement
              Workaround :
              Replacing the HDD resolved the
              E748-2010 Error Code.
              Part Number
              = FK2-9316-000.
              also
              E748-2010
              Issue was resolved by replacing Sata Flash PCB & Main Controller 2.
              Sata Flash PCB, FM4-7941-000
              Main Controller 2 PCB, FM4-7908 for IRA4051,4045,4035
              • Brian8506
                • 1666
                I'm having this problem as well. The part numbers for the flash pcb don't come up in the parts manual. Does anybody know where the flash pcb is? Is it on the main controller? Nothing on there with an orange led on. Not sure if the hdd is gonna take care of it but I want to make sure I'v tried everything suggested.
                Workaround :
                • morph163
                  • Nov 2022
                  • 2
