Load Paper
  • markdmt
    • 76
    [Misc] Load Paper
    I have another C6000VP that every time i submit a job to the printer it forces me to select the paper tray even if it has the paper in the tray and programed for the correct size and weight. it doens't matter if it is 12 X 18 thick three or standard letter plain. Does anyone know of a setting that could be turned off to let it go without selecting every time i submit a job. Once it is selected the first time it will pull from all of the trays that have that weight and size. It seems like a interpretation on the machine side from the job submission, it is not the server because I switched it between C6000VP's and it only does it on this printer. Any help would be appreciated. This is more annoying than anything. thanks Mark
  • teckat
    • 16083
    Re: Load Paper
    Is this from all apps u use for printing_?
    • niyaskarimba
      • Sep 2014
      • 110
      Re: Load Paper
      Please press additional function- printer setting - settings - paper feed -paper size over ride to ON
        • 23010
        Re: Load Paper
        To me, it seems like the driver is defaulted to a specific tray or size. I would select "Any" or a more commonly used size.
        Are you using a Fiery or other print controller? In my experience with such controllers, the paper has to be the exact same specifications: type, weight, color, whatever ... or it will ask you to load paper. =^..^=
