Canon IR 7105 drum
    • 16083
    Re: Canon IR 7105 drum
    Originally posted by copierpoint7
    Respected Brother,
    i am not a technician i have the little bit service knowledge , recently i buy one rc machine ir 7086 , it have two dots
    one is ark and the another is a physical dot can you please tell me is the nail polish Technic will work on this
    please help help help help help help
    thanks
    Will not work
    • V-P
      • Apr 2011
      • 679
      I can confirm from experience.
      1. Nail polish will NOT work
      2. White Eraser will not work
      If you have a spark and apply nail polish - you will make the spark or some other shape bigger than before.
        • 16083
        many more Thanks to brother teckat
        & Brother V-P for your fast reply
        brother i have one more doubt my machine shows when it turn on it was ask department id and Password then i do PWD CLEAR in additional function then it was ok , the next day when on the machine
        it was ask the same dept id how to solve pls help?
        the importer reset the counter the all values are showing 0 , how to find the original counter to the machine
        , how to check laser life in this machine
        thanks
        You mean under the Counter Check on control panel, all counters are zero_?
