Lanier 5635 Service code SC390
  • hollisizer
    • Mar 2025
    Lanier 5635 Service Code SC390......Easy fix?
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    TD sensor error: Test value abnormal
    The TD sensor output voltage is less
    than 0.5V or more than 5.0V after 10
    consecutive times during copying.
    • deep
      • Jun 2008
      • 208
      Abnormal toner concentration or a bad TD Sensor or the sensor not connected properly.
      Kenny
      • hollisizer
        Do I need to clear code or does it clear when problem is fixed?
        Thanks for the help guys!
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          nope.
          • iMind
            • Mar 2008
            • 1116
            There are 4 levels of service call conditions.
            Level Definition Reset Procedure
            A Fusing unit SCs displayed on the operation panel.
            The machine is disabled. The user cannot reset the
            SC.
            Enter SP mode, then turn the
            main power switch off and on.
            B SCs that disable only the features that use the
            defective item. Although these SCs are not shown
            to the user under normal conditions, they are
            displayed on the operation panel only when the
            defective feature is selected.
            Turn the main power switch off
            and on.
            C SCs that are not shown on the operation panel.
            They are internally logged.
            Logging only
            D Turning the operation switch or main power switch
            off then on resets SCs Displayed on the operation
            panel. These are re-displayed if the error occurs
            again.
            Turn the operation switch or
            NOTE: 1) If the problem concerns electrical circuit boards, first disconnect then reconnect the connectors before replacing the PCBs.
            2) If the problem concerns a motor lock, first check the mechanical load before replacing motors or sensors.
            3) When a Level A or B SC occurs while in an SP mode, the display does not indicate the SC number. If this occurs, check the SC number after leaving the
            • juan carlos guardado
              sc-390 in 5635
              type the keys as follows : clear modes (yellow key) , 107 , Clear stop red key and hold it down until the SP-mode menu is displayed (about 3 seconds) and turn off the copier
              • Fearless V K
                • 620
                Have seen this with either extremely dirty machines, ones that need drum and/or developer replaced, or have a bad toner supply unit (mylars missing).
                If it's just dirty, clean out the drum unit, vac out the machine, and you should be good to go.
                Don't take that toner with me!
                • hollisizer
                  Oddly enough it was cured after replacing the toner cartridge but I have some great ideas if it comes back!
                  Thanks for the help!
