Erroe code E 804 -0007 on iRADV C7055 at power on.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    Good saturday to everybody !
    Another fault I found on my road !
    I changed the relative fan;
    I cleaned the rear connectors of the feed unit !
    But I have the same code !
    Solutions ?
    Thank you !
  • laitang
    • Nov 2012
    • 627
    Re: Erroe code E 804 -0007 on iRADV C7055 at power on.
    E 804 -0007: A failure was detected at the IH power supply fan (FM7).
    1. Check the connection of the connector.
    2. Replace the IH power supply fan (FM7).
    • teckat
      • 16083
      Intermittent E804 - 0007 was indicated at power on. A failure was detected at the IH Power Supply fan (FM7).
      In one case, after inspecting the fan FM7 and in IO mode at address P028-bit 8 indicating "0", it was decided to replace the IH Power Supply and the fan FM7 at the same time to resolve this error code.
      IH Power Supply Fan FK2-3679-000 (FM7)
      IH Power Supply PCB FK3-9584-000 (UN30)
