Canon C2020 Error E000009-0000. Can someone let me know what this error is in regards to? Thanks!
Tags: None
Re: Canon C2020 Error E000009-0000
From SM:
E009-0000:Fixing Film Unit engagement / disengagement error
Detection: There is no change in the result of detection by the Fixing Pressure Release Sensor even after five seconds elapsed after counterclockwise rotation of the Fixing Motor started.
Remedy: Possible cause is overload or rotation failure of the motor
due to an electrical trouble
1. Check if the Fixing Assembly is installed.
2. Remove and reinstall the Fixing Assembly
3. Check the gear
4. Replace the Fixing Assembly
5. Check the harness/connector between the DC Controller PCB (UN09/ J210) and the Fixing Motor (M17).
6. Check the harness/connector between the DC Controller PCB (UN09/ J12) and the Fixing Pressure Release Sensor (PS24)
6. Check conduction of FU1153 in the AC Driver PCB (UN14)
=> Replace the AC Driver PCB (UN14) in the case of disconnection.
7. Replace the Fixing Motor (M17)
8. Replace the DC Controller PCB (UN09)Comment
