Canon C2020 Error E000009-0000
  • adamcopiercali
    • Aug 2012
    • 88
    Canon C2020 Error E000009-0000. Can someone let me know what this error is in regards to? Thanks!
  • canon33
    • Jun 2014
    • 65
    Re: Canon C2020 Error E000009-0000
    U need a new fixing unit
    • vamoursly
      • Sep 2011
      • 273
      and no its a complete part swap, I have tried to rebuild them without any success...
      Inspect the film, you probably have a tear in it, theese fuser just love doing that on these models
      • laitang
        • Nov 2012
        • 627
        From SM:
        E009-0000:Fixing Film Unit engagement / disengagement error
        Detection: There is no change in the result of detection by the Fixing Pressure Release Sensor even after five seconds elapsed after counterclockwise rotation of the Fixing Motor started.
        Remedy: Possible cause is overload or rotation failure of the motor
        due to an electrical trouble
        1. Check if the Fixing Assembly is installed.
        2. Remove and reinstall the Fixing Assembly
        3. Check the gear
        4. Replace the Fixing Assembly
        5. Check the harness/connector between the DC Controller PCB (UN09/ J210) and the Fixing Motor (M17).
        6. Check the harness/connector between the DC Controller PCB (UN09/ J12) and the Fixing Pressure Release Sensor (PS24)
        6. Check conduction of FU1153 in the AC Driver PCB (UN14)
        => Replace the AC Driver PCB (UN14) in the case of disconnection.
        7. Replace the Fixing Motor (M17)
        8. Replace the DC Controller PCB (UN09)
        • MFPTech
          • 486
          Put a new fuser, don't forget to swap the duplexing part and be done with it.
