ir400 dev/ dev drive problems?
  • MunsterTech
    • Sep 2014
    • 381
    [Misc] ir400 dev/ dev drive problems?
    Hi guys,
    went to a ir400 2 weeks ago, dev assy had seized, only 87,000 on the meter. I ordered a new dev assy, but never went back as I was away. Another tech went to do the RTF an put in the new dev assy, but said it kept asking to supply toner and wouldnt actually allow the supply to happen. It would go thru the motions but nothing.
    Anyone had any problems with devs/dev drive, toner supply etc? Going back myself tomorrow and a heads up would be appreciated.
    tks Munstertech
    • 23007
    Re: ir400 dev/ dev drive problems?
    Is there any developer drive? If not, clearly the seized developing unit broke additional drive gears in the back. Seems obvious. Doesn't it? =^..^=
    • MunsterTech
      • Sep 2014
      • 381
      went back to this machine today, tried a toner stir, but no toner entering the dev assy, took out the toner cartridge and in the machine where the dev sits, there is a lever and a shutter, when the lever is pushed back the shutter opens and allows toner to fall into the dev. This was not happening, no toner falling. Put my hand into where the toner bottle sits and at the back, a build up of toner, pushed my finger down the aperture and totally compacted. Also seems to be something broken, a paddle or stirrer as its just floating around in the big pile of toner. Ordered a new hopper assy, had a little chuckle with the customer as it was so obvious!
        • 23007
        Congratulations. =^..^=
