Canon IR5050 drum assy removal
  • greenbean
    Midwest Regional Manager
    • Jun 2014
    • 27
    I am trying to remove the drum unit assy but it will not slide out. The manual says 2 screws and 5 connectors and it should come out. Does the developer assy have to come out even though the manual does not mention it? Thanks for any ideas. This is my first time working on this canon and i do not want to damage that expensive drum.
    Thank you
  • roho
    • Mar 2009
    • 844
    Re: Canon IR5050 drum assy removal
    Yes, the dev assembly should be removed, it probably has a build up of toner on the outside of the cover facing the drum that should be cleaned anyway.
    • laitang
      • Nov 2012
      • 627
      Thank you
      From SM:
      Before Removing Process Unit
      1) Detach the front cover.
      2) Detach the toner supply cover.
      3) Remove the primary fan duct.
      4) Remove the developing assembly.
        • 22929
        Thank you
        I applaud your wisdom on this point. It's something like the Hippocratic Oath for technicians: "Do no additional damage ..."
        ... and yes, it's the developing unit that's holding you up. It comes out through the right side door, behind a metal panel held with a single screw, and slots into the rear frame. =^..^=
        • greenbean
          • Jun 2014
          • 27
          Originally posted by laitang
          From SM:
          No my downloaded pdf manual does not mention step 4 but thanks for your sarcasm.
          • livancicm
            • Sep 2008
            • 96
            3 screws
            • Canuck
              Tech Specialist
              • 1713
              Did you remove the lock screw and key from the end of the drum shaft? The shaft remains in the machine and the process unit slides out, along with the rails that it sits on. Open the transport drawer and put a sheet of 17 inch paper over the transfer/sep corona assembly to keep toner out of it and help protect the drum from getting scuffed as you slide the process unit out. I don't always remove dev unit...just remove the side cover,do not unplug it,just pull it back about inch so that dev spacers are nowhere near drum and slide out process unit.
