iR8500 problem
  • tee2520
    • Jun 2013
    • 37
    [CQ] iR8500 problem
    When I copy from ADF and flatten glass is solid black output as the photo attached. Please advised. Thank you
  • tenatal
    • Aug 2011
    • 35
    Re: iR8500 problem
    Did u remove / refit the primary charging units.
    if this units are not properly fitted the above problem can come
    also faulty HVT could be reason for same.
    • laitang
      • Nov 2012
      • 627
      Re: iR8500 problem
      1/ Check the scanning lamp
      Is the scanning lamp ON?
      2/ Check the pre-exposure lamp
      Is the connector of the pre-exposure lamp connected?
      NO: Connect it.
      3/ Check Primary charging assembly
      4/ Check the connection
      Is the connection between the following PCBs normal?
      1. Image processor PCB
      2. CCD unit
      3. DC controller PCB
      4. Relay PCB
      NO: Connect them properly.
      5/ Check Reader controller PCB, CCD unit
      Does the problem occur only in copy images?
      NO: Perform the following:
      1. Replace the reader controller PCB.
      2. Replace the DC controller PCB.
      YES: Replace the CCD unit.
